My rear sway bar broke!
I was turning a corner and it snapped in half. The whole rear end swayed so bad that I couldn't steer cuz the car was swerving back and forth. Anyways I got it home and got a new one. Now I can't get the stupid bolts off! I snapped my breaker bar trying! Should I use heat...it's pretty close to the gas tank and WD-40 doesn't seem to work.
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Why is everything but the bolts snapping? You can try heating and cooling it and see what it does.That has helped me a couple times.
Car: '82 Z28
Engine: none!
You <i>broke</i> a breaker bar? Damn.
I had to take off some rusted-solid nuts from a junkyard spindle recently, so I definitely concur with the suggestion of using heat. When all else fails, get out the blowtorch.
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i broke the bolts trying to get my antisway bar off the rear. in fact it still isnt back on yet.
Car: '87 Camaro LT
Engine: 355 L98
try penetrating lube like blaster or the like instead of wd-40 which is more of a lubricant. if that doesn't work use a propane torch.
here's a simple,cheap suggestion if you mangle the u-bolts that go over the diff. Go to your local parts store and get exhaust clamps. 2 1/4 i believe. Worked like a charm for me!
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
cut the bolts with a sawsall if you dont want flame near tank.
it will cut through them like nothing
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
