Should I replace the pitman arm??
Car: 1998 Dodge Ram 1500 4X4 Quad Cab
Engine: 360 V8
Transmission: R47RE 4 spd auto
Axle/Gears: 9.25 rear/DANA 44 frt / 3.90 gears
This saturday I am replacing the front suspension and steering. I am installing new:
Energy Suspension LCA bushings
Energy Suspension bump stops
Moog Center Link
Moog tie rod adjusting sleeves
Tread Saver(made by federal-mogul) idler arm
Tread Saver Inner & Outer tie rods
Tread Saver Ball joints
I also have polyurethane caps for the tie rod ends and the ball joints. Next spring I plan on installing new eibach springs and bilstein shocks and struts. When I go back in to do the front end, should I replace the pitman arm. I have been told this is a non-wearing part, and the dealer is the only place I have found it and they want $129 for it.
Your opinions and suggestions are appreciated.
Moog Center Link
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
No, it's not necessary to replace the pitman arm unless you somehow bent it in an accident or something....otherwise it would be a waste of money. I just got done rebuilding my whole front end yesterday and the part that had a lot of slop was the idler arm...that would explain the popping noise I used to get when I made sharp turns. Everything else was surprisingly tight.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
