Panhard mount
Panhard mount
My panhard bar must have gotten loose over time and wiggled enough in the mount that it has oblonged the hole. All it does is vibrate and rattle. How can i fix this without welding because i have no way to use a welder? How much do u think it would be if i took it to a shop?
Re: Panhard mount
How badly oblong is it? The stock bolt is tapered so the whole is larger on one side then the other, you may be able to get away with just drilling the small side larger and using a straight shouldered bolt. If that's a no go, you may want to check the size of the whole in the bushign sleave, most are slighly larger then the bolt used, so you could actually get away with using the next size larger bolt.
Hotrodboba400
Dec 10, 2019 07:07 PM
camaro1185
Oct 26, 2015 06:51 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
