Shock or Strut
Old Mar 5, 2004 | 12:19 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Shock or Strut
What the heck is the difference between a shock and a strut?
Old Mar 5, 2004 | 09:07 AM
MdFormula350's Avatar
on thirdgens the fronts are called struts. the shocks are for the rears.
the struts mount differently to the car.
thats a front strut.
rear shock.
Old Mar 5, 2004 | 10:42 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Struts and shocks do they same thing. They dampen spring vibrations. The difference in name comes from how it is mounted to the car. Stuts will take the place of a suspension part(in our case its the upper ball joint. Whereas the shocks just mount to the existing suspension. A good rule of thumb is that if you can take it out and still drive the car its a shock. Otherwise you have a strut.
Old Mar 5, 2004 | 11:39 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the most common place to find a strut is a macpherson strut which the spring, strut, and bearing plate are all together and can be removed by 5 bolts. our cars have what they call a modified macpherson strut set up, each of those components are seperate on our cars
Old Mar 8, 2004 | 03:41 PM
cool..thanks guys, that helps
stinking lingo:lala:
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
