Eibach Pro Kit users
Old Jun 26, 2004 | 10:15 AM
IroczInOz's Avatar
Has any of you measured how much ground clearance you have with these springs? When I talk about ground clearnace what is the smallest clearance you have under the car to the ground? Probably either the Cross Member or the Trans-Pan.
I am thinking about getting the Pro Kit's after reading about them and most seem to agree that they feel better then the sportlines.
My Iroc has had it's springs cut the $hit out of them. The car looks wicked as it is but I have trouble driving over ants on the road.
Not sure how much was cut off them but when I measured how much clearnace I actually have I measured 2.5".
So I was wondering if I installed the pro kits how much I can expect to gain. To be on the safe side you need roughly 4".
Old Jun 26, 2004 | 10:49 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd say that's about what I have at the trans area. I can scrape going over speed bumps but that's about it. I also scrape the air dam a lot more but they're fairly cheap. As another option, a lot of guys install Moog replacement springs that are pretty stiff but keep the stock ride height.
Ed
Old Jun 26, 2004 | 11:05 AM
IroczInOz's Avatar
So you have about 4" with the Pro Kits?
Old Jun 26, 2004 | 01:14 PM
ebmiller88's Avatar
Yeah...about 4-5". But the ride is worth it. I love it.
Ed
Old Jun 26, 2004 | 01:22 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I'm not too sure on what the specific numbers are for my ride height, but yes, they are real nice springs. Can clear most easy speed bumps with ease and some really tall ones I have to be careful on or I scrape the exhaust. My front nose can still barely go over 99% of the curbs when I park in a parking lot. The height looks nice too.
Old Jun 26, 2004 | 06:52 PM
IroczInOz's Avatar
Do any of you have have a picture of your car so I can see the wheel gap?
Mike
This is what mine looks like currently:
Old Jun 26, 2004 | 09:06 PM
ebmiller88's Avatar
Sure:
Old Jun 27, 2004 | 12:29 AM
IroczInOz's Avatar
Cool judging from that picture your back end is definitely higher buy a bit, but the front is pretty close to same as mine.
Thanks for that.
MIke
Old Jun 27, 2004 | 03:21 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i believe ed has the 4th gen isolators. running 245/45/17 all around i have about 1.5 gap, pics next week (HOPEFULLY)
Old Jun 27, 2004 | 06:03 AM
IroczInOz's Avatar
One last question how do the spring rates compare to IROC-Z springs? Are they softer, stiffer, or same?
MIke
Old Jun 27, 2004 | 11:33 AM
ebmiller88's Avatar
I removed the 4th gen isolators, that's the car with the stock ones in it. The back does sit up a bit in that pic but I don't think it does now.
Here's the link to that whole thread:
https://www.thirdgen.org/techbb2/sho...ghlight=stance
Ed
NORTz89
May 20, 2020 03:51 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
LT1Formula
Aug 20, 2015 09:36 PM
