1LE brake hose question stock type hose
Car: 1989 Firebird Formula
Engine: V8
Transmission: TH700
I got the 1LE brake upgrade off my brothers Camaro but I am uncertain whethere I have the hoses correct (left and right).
Currently the only way the hose will bolt to the bottom of the caliper without getting all twisted is if the hose curves up at the bottom end of the caliper. Should it curve down or am I correct with having it curve upward?
What is the difference between the left and right side stock hose?
Can anyone give me some advice whether I have this on correctly? It does seem as though there is a bit of tension on the hose end where the banjo bolt is but I did reuse the factory hose bracket on the strut and all the factory clips are on correctly.
Any help would be greatly appreciated as this is my only concern.
Thanks! :hail:
Thanks! :hail:
Engine: V8
Transmission: TH700
thanks so much for the help guys. It seems as though I have them backwards then. I will swap the hoses and run them underneath the caliper.
Can't thank you guys enough :hail:
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
