trans fluid question
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I was told by a friend he took his t5 out and noticed that the fluid in it looked thin like auto fluid.he then called GM and they told him that this is what they use because all it needs is some fluid to keep it cool..which i think this is bulls#!^ on there part if it is true ..so he put gear oil in it and said could tell a whole lot of differance in shifting...anyone heard of this...im going to check my t5 this weekend
Axle/Gears: 3:08
how is that possible ...it is the same principale as a rear end..with the gears being in contact with each other...doesnt it need more lube than some atf...just wondering man i was shocked to hear that
Axle/Gears: 3:08
i dont know im not a trans man...i just thought since the fluid didnt flow thru a cooling device like the radiator on an auto it would break down and loose viscosity with the heat and make the trans succeptable(however you spell that hehe)to excess wear...not being a jerk just making conversation
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally posted by Apeiron
The world-class T5 takes ATF, not gear oil.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by dwillis
i dont know im not a trans man...i just thought since the fluid didnt flow thru a cooling device like the radiator on an auto it would break down and loose viscosity with the heat and make the trans succeptable to excess wear
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: trans fluid question
I've got the details saved on my home computer somewhere, but in a nutshell —_gear oil attacks the linings on the syncros. If you run gear oil too long, you will have trouble downshifting the trans.
Then there's the possibility the lubrication passages are so small on some components that gear oil will not flow readily and lubricate properly. It was designed to use ATF, so stick with ATF.
I have some first hand experince with this. I almost bought a used WC-T5 for my GTA. A reliable mechanic inspected it for me and told me it had gear oil in it, instead of ATF. He felt it would be okay and recommended dumping the gear oil and refilling with ATF.
Well, another friend informed me of the potential fiasco the trans might have, so I passed on the deal. Another friend bought the trans and sure enough, he complained he couldn't downshift the trans at all while driving. He had to pull it back out.
Axle/Gears: 3:08
well gm built it to take atf so i will stick to it..my theory is to not fix something if its not broken...my friend sold his T/A so he wont care now...we put a 400 pontiac in it.i could kill him for not giving me first dibs on it and he is still kicking himself for selling it to a kid that destroyed it....Thanks for the info guys
84z96L31vortec
Aug 20, 2017 12:16 AM
maroe624
Apr 16, 2017 08:29 AM
