Will I have problems?
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Currently I have Goodyear 225/60/16 tires, but I plan on replacing them with some Falken 255/50/16 tires from tires.com. I have a coil removed from a set of new moog springs, but I plan on getting a set of real lowering springs at the same time as the tires. Will I be able to run the 255/50/16 tires up front without issues with a 1" to 2" inch drop? I'll get another alignment then too.
Car: 91 Camaro RS
Thanks phoenix305. I'll probably have to watch the parking lots, but I do that already.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You probably won't have any problems with the outside of the fender, but you might hit the inner fender if you turn sharply.
Car: 91 Camaro RS
I forgot to put that I have done the ls1 brake upgrade, so the front wheels are another 3/8 inch out.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yeah you should be fine but 255 is probably the biggest you want to go with it.
Car: 91 Camaro RS
What alignment specs should I go with if I have dropzones and 255/50/16? I do mostly stop-light to stop-light driving and inner city highways. I want to try and get 30k miles out of them, so its not going to be beaten constantly.
Car: 91 Camaro RS
Yeah, I've got some rub now. I just put the Yokohama Avid V4s 255/50/16 on the front and I've got some rub at moderate turn. The rub is occuring on the plastic so I figure if I rotate the tires and have the "rears" on the front I will get less rub. Does that make sense? I'm hopefully going to have time to try tomorrow.
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I'm surprised that you are getting rub at moderate turns. I autocross with 255 hoosiers and only get moderate rub. You may want to try the BFH to gain some clearance.
Car: 91 Camaro RS
Yeah BFH and I think I'll trim the plastic fender guard down or remove it.
