how much rubber can you fit?
Old Jun 5, 2006 | 05:16 PM
ChevyRS-305's Avatar
i was wondering how wide of a tire some of u guys have fit on your third generation's stock chassis. I was wanting to have a 10" wide tire on all 4 corners, but i dont know if there will be enough clearance between the edge of the tire and the wheel well. I was just wondering what some of you are rolling on out there....
Old Jun 5, 2006 | 05:22 PM
Blk90iroc's Avatar
so you were thinking a 275? tires dont come in inches they some in mm's, rims come in inches a 10 inch rim will fit in the back with 275's no prob
Old Jun 5, 2006 | 05:52 PM
Shagwell's Avatar
Car: projects.......
I don't think you can go more than a 275/40 in the front. I'm running 315/35's(approx 11.5 wide) out back, but if I was any lower they'd rub the fender lip. - do a search. Fat tire combos have been posted many times on this board.
It also largely depends on the wheel size you intend on running.
Old Jun 5, 2006 | 06:11 PM
Stevo's Avatar
Car: Pair of 92 Z28s
285s here and thats up to the fender not past it.
Old Jun 5, 2006 | 09:27 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
265's here no prob at all..
Old Jun 6, 2006 | 11:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
your turning circle becomes a PITA with fatter then stock tires. I only have 235/60/R15's on 15x8 up front, maybe I have a poor offset, but getting into parking spots takes two tries due to rubbing on the plastic fenderwell.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Dec 10, 2015 08:16 PM
New2Chevy
Sep 28, 2015 12:35 AM
tglennon11
Sep 23, 2015 05:30 PM
Formula_88AE
Sep 3, 2015 01:47 PM
