Cheapo Spring Compressor
Car: 91 Z28
Engine: TPI 350
I just used this to get my original Springs out...
Compressed til the upper metal piece sat on the a-arm so it cannot slip off the spring...
after the a-arm is out you can loosen this and take the spring off of the arm...
I put in a throw-out-bearing on the lower end so it spins better when compressing. The lower nut is welded onto the threaded rod.
I know its cheap but it worked fine for me..
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Cheapo Spring Compressor
whatever it takes/works , just hope you used grade 5 or better hardware . seems like a decent idea . good luck .
2012sergen11
Oct 13, 2015 07:38 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
