Do spindles interchange?
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I just wondering if the spindles between firebirds and camaros are able to be swapped with one another. Or would they be slightly different in how the dust sheild mounts and/or how long the thing the tie rod attaches to is? I'm asking because I may have found a good deal on a set of firebird spindles to mod for the brake upgrade for my IROC-Z.
My guess is that they are the same but I just want to be positive.
Mike
Mike
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Do spindles interchange?
there is a LOOOTTT of cars and even trucks that have interchangable spindles. like s-10s some blazers etc etc. im sure firebids do, ou spindles are VERY common.
Car: 87 GTA
Camaro & Firebird spindles do interchange, but (AFAIK) do not interchange with any other GMs, like the S10/S15. Our strut suspension would prevent interchangeability with dual a-arms front suspensions (S10/S15, C/K, Impala/Caprice etc.)
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Yes the F-Body suspension is rather unique in the GM lineup, I suppose this is due to it's limited travel requirement. Camaro/Firebird spindles are the same 82-92 as far as I know, EXCEPT the 1LE/B4C cars but these are rare.
Car: 1987 IROC-Z
Transmission: TH350
That's exactly what I wanted to hear.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
They interchange. They did from my parts car (91 Formy) to my car. But, you may need an alignment. The only thing I changed was the spindles (didn't touch anything else) and the toe was off 7/8 of an inch...
rb85TA
26
Sep 14, 2015 10:29 PM
50, 92, axles, blazer, camaro, car, custom, dana, interchange, interchangeable, interchangeble, s10, spindle, spindles, suspension
