sway bar choices please help
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i found a great deal on a new spohn rear drag sway bar set up. im ready to buy bars but dont know what size to get for the front and if this will be too big for my iroc
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: sway bar choices please help
if you are planning to use a drag bar on the rear, the car would be more of a drag orientated car, and you would be using a very small front bar, if one at all. But it will roll alot on the street when you turn.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
it will not be used for drag just trying to put together a nice handling car. what are your suggestions on brand and size
Hello, i just wanted to give you another option for your sway bars. Our front bar is a 32mm and the rear a 25mm. These bars will greatly increase the cornering capabilities of your car. Our bars are made from cold formed steel to better resist torsional fatigue and retain their memory far longer than conventional hot formed bars. They come complete with all end links and bushings. Our bars are available in either black hammertone or red. Here is a link to our site. If you have any questions or would like a set please give me a call here at the office.
http://www.bmrfabrication.com/F3.htm
gixxer92
05-18-2017 11:20 AM
darwinprice
17
10-11-2015 11:51 PM
