sway bar sizes for 91 formula
Hey all , I need toknow what the sizes are for the fron and rear sway bars are for a 91 formula , i want to order poly bushings for it , but car is at home and i dont remember what size they are ,
thanks
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
http://www.oldsrocket.com\91bird
and the for ever returning CODE 32
thanks
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Hotchkiss STB
SLP exhuast
CatCo Hi Flo Cats
The fronts could be 32mm, 34mm, or 36mm, and the rears can be 19mm, 21mm, or 24mm. Every car is different so you really need to measure them. However, all Formulas that I know of come with the WS6 package, which is usually the 36/24 combo.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
There was also a 23mm bar for the rear as well. Also,just because the car has WS6 DOESN'T mean it has the 36/24 combo. Check the latest GMHTP for the suspension article on Magnum TPI. That car has the 34mm bar up front. Check your RPO label in the console. The cars with FE2 usually but not always came with the 36/24 combo. FE1 and Y99 had the smaller bars.
Hope this helps.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Hope this helps.
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
