Parts for a brake overhaul
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
What parts do I need to change or inspect for a brake overhaul? I have 4 wheel disc and I would like to put Delco parts in. Thanks
1989 Formula 350
1989 Formula 350
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
All the basics would be:
rubber flex hoses
caliper piston seals & boots
mounting bolts
pads
a good DOT3 (min) fluid
speed-bleeders (instead of the factory bleeders)
rubber flex hoses
mounting bolts
pads
