Relocation brackets????Help!!
Old Nov 28, 2001 | 04:26 PM
big green monster's Avatar
Do you absolutely have to have the relocation brackets for adjustable lower control arms. Help guys......
92 Teal RS
305 TBI
Thermomaster Chip-160Deg Stat
K&N
Custom Throttle Return Bracket
Heddman 1-5/8 Headers
Hooker 3" (Y-Pipe Back)Dual 2-1/2 Outs
Intrax 2" Springs, Spohn Panhard,
17x8 Sabers
Old Nov 28, 2001 | 05:56 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no , you don't NEED them, but they help traction ALOT, and if your car is lowered, they will return the LCA to the corect angle.
Old Nov 28, 2001 | 06:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, you don't have to have the brackets, but...
The brackets will do about 10 times more for your traction than the LCAs themselves will, for less $$$.
If this is the car in your sig, the LCAs won't make a noticeable difference. The brackets will fix your obvious extreme wheel hop. Don't waste your $$$ on the LCAs until after you've tried a set of brackets.
ICON Motorsports
Old Nov 29, 2001 | 07:50 AM
82camaro's Avatar
Car: 82 camaro SC
What RBL69 said. Try the relocation brackets first. They stopped my wheel hop problem.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
