template of the rear reinforcement plates
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello all
can anyone help me with a template of the rear reinforcement plates
from a coil over set??
i buyed a coil over kit from QA1 Spohn from a guy,but he had the reinfrocement plates welded on his car.
i live in the netherlands and they hard to find here.
so i hope somebody will make a template for me and send them by e-mail.
d.vanmierle@chello.nl
i will pay a little price for it if you want.
please let me know fast as you can.
need them.
thanks Dennis
need them.
thanks Dennis
1 Post
Car: camaro iroc-z
Re: template of the rear reinforcement plates
common guys
there must be someone who can make me a template of thes plates.
please help me.
Dennis
please help me.
Dennis
He's in the Netherlands like me, if he buys the plates they will be close to 300 bucks or so when at his door because of the insane shipping fees and import duty and taxes. IF he can cut it himself he's done for a couple of bucks.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
One of the many reasons I got out of Europe a long time ago!
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Yep, Tried to get those plates from Spohn, they said they buy them in sets with the shocks....LOL
I'd buy their set up, but thee shocks wont work on my car....Lowered.
Terrible!
Anybody have a template?
Terrible!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
maybe....
I happen to be the guy that designed it and gave the idea to Steve Spohn. It is very simple to do just as Jim85IROC suggests. That is how I did it originally. I also helped spohn with technical advice on the front setup also but have long lost all the data on my old computer that crashed several years back. The fronts I suggested to him to use the Torrington thrust bearings on both side of the springs since the coilover had to twist in steering rotation to turn the car.
Dean
Dean
I would also suggest to you to use BMR's "bolt-on LCARB's" but also weld them into place.
Why?
Because the added "bolt-on" leg of the assembly added extra strength to the bottm of the mount where the coilover sits it's weight upon.
Then you can grind the old spring pocket mounts off the axle to shave weight- especially the bulky driver side, and refit the PHB mount with a jegs unit that is boxed with lesser material comining off the axle vertical top and bottom rather than that massive and ackward boxed spring cup
Why?
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
1/4" steel - no need to be exact to make your own.
These pics should help.
Brian
Brian
Car: 87 RS Camaro
Engine: LS6
Thanks,
BTW, do you have front coilovers as well?
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
No, I put all this junk in.
However, I did use the plates for the coil-over (bottom left) for additional assurance, just like the rears.
1992 Trans Am
05-10-2023 07:19 PM
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
