Founders Performance now stocking Vogtland Sport Springs
Old 10-07-2015, 02:20 PM
  #101
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: Founders Performance now stocking Vogtland Sport Springs
Just put mine in today along with new AGX's... and the thing sits like a lifted truck in the front. I removed the isolators and used heater hose too! Hope it settles...
Old 10-07-2015, 02:46 PM
  #102
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You know I've read about 'settling' many times, but frankly, my moogs never changed a millimeter that I could measure/see. Several months after the swap, I finally cut them.
JamesC
Old 10-07-2015, 03:18 PM
  #103
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
My factory Moog Springs still have skyjacker ride height status.
This is with the iron LT1 heads, so weight is pretty much the same as L98. I now have the AFR 195's on there and its taller up front still. Enough so that I've got some positive camber.
Old 10-07-2015, 04:11 PM
  #104
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
ugh...don't scare me guys. the thing looks silly.
Old 10-07-2015, 06:42 PM
  #105
JamesC's Avatar
Indexed?
JamesC
Old 10-07-2015, 07:02 PM
  #106
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Originally Posted by JamesC
Indexed?
JamesC
As in, rotated correctly? I really thought so. Kinda hard to mess that up, right? Or no?
Old 10-07-2015, 07:54 PM
  #107
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
I just installed a set of these and my car is sitting fine. Slightly lower in the front than the back. I've got an aluminum headed, carb'd small block.
Looking at your info, that car doesn't still have the V6 does it?
My other question would be are you sure the spring seated in the upper pocket? Having installed a couple of sets of springs now, I know that can happen depending on how you go about the install.
Old 10-07-2015, 08:39 PM
  #108
JamesC's Avatar
Spring end rests between the two drain holes.
JamesC
Old 10-08-2015, 05:47 AM
  #109
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, knowing that I'll go check. It is a V6 car but still.
Old 10-08-2015, 07:23 AM
  #110
87v6Bird's Avatar
Engine: 406, LB9
I'd say this is the main issue. The springs aren't going to compress as much with ~250 lbs less weight in the front.
Old 10-13-2015, 01:43 PM
  #111
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
As much yes, but damn... I have 5" of gap now!
Guess I'll pull em and cut em down a bit. Hate doing that to new springs but can't afford coilovers yet!
Old 10-16-2015, 10:09 AM
  #112
On Probation
SlickTrackGod's Avatar
ALuminum head V8's LS1's fiberglass hoods, etc etc.... the V8 cars are still heavier then the little 60*V6 cars. Like stated, this package is about 250lbs lighter over the nose on the car. You have to cut the V8 performance springs to get them to sit correctly in a V6 car.
This is proof once again that even an LS motor is still far heavier then a 60*V6- Ive been telling this for years. It is why the V6 cars can be made to handle on an autox course like a jetfighter.
Old 10-28-2015, 01:42 PM
  #113
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Made another phone call. Was told Vogtlands are in fact progressive rate springs. Yes, the first few coils are there to hold the springs in, and don't sound like they provide much force (dead coils), just height. But the working part of the spring is progressive.
This is where Founders chimed in earlier, so I would think I was told accurate info.
https://www.thirdgen.org/forums/susp...ml#post5698690
Old 10-28-2015, 02:42 PM
  #114
What founders wrote doesn't read as progressive, its dual rate.
Plus, you can see it if you look at the picture I posted, the unloaded distance between coils is equal, then changes to another distance. Its two rates in one spring, but its not progressive.
Old 10-28-2015, 04:54 PM
  #115
LiquidBlue's Avatar
Transmission: MD8
Maybe I don't understand what progressive is. My definition would be as the spring compresses, its force goes up. It would have a force curve that went higher as the spring compresses. My guess is where the dual nomenclature comes in is when the car is up in the air, wheels hanging free. The "dead" coils have their own "non-working" rates. But in the end, when you are driving the car, is what matters. As founders states, the "working rate" starts at some value and progresses higher until bump stops are hit.
Well, heel, as I wrote this I got off my lazy hands and googled it real quick Here's a nice definition:
http://automotivethinker.com/suspens...-rate-springs/
Old 10-28-2015, 05:05 PM
  #116
The founders front springs aren't progressive at all, the coil's per inch is even on sides. You can see the clear separation in spring rates.
Basically the softer side is so soft that when the car is on the ground its full compressed all the time.
Old 10-28-2015, 06:35 PM
  #117
LiquidBlue's Avatar
Transmission: MD8
Here is some info on what you are saying Bill : http://www.vikingspeedshop.com/suspe...-spring-rates/
Old 10-28-2015, 06:40 PM
  #118
Here is some info on what you are saying Bill : http://www.worksperformance.com/html...rate_desc.html
That might be true of the lower rate of the Vogtlands was strong enough to support the car, its not. It collapses fully and becomes static, having zero effect in controlling the cars weight.
The low rate portion of the spring is designed to collapse fully once the weight of the vehicle is on it. It does not do any work unless you lift the car to the point that it can uncompress. Even then, the struts don't allow that full travel.
So while yes the spring is technically dual rate, one of the rates is entirely ineffective at the installed height.
When installed they function as a single rate spring.
Old 10-28-2015, 08:29 PM
  #119
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Those white wheels look good.
Old 10-30-2015, 10:00 AM
  #120
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So, weeks later and my headlights still aim at the sky. Going to chop some coils off. How many should I go for you think?
Old 03-11-2016, 11:28 AM
  #121
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Founders: Do you guys ship these springs to Canada? It doesn't seem to work on your site. Thanks.
Old 03-11-2016, 11:32 AM
  #122
Former Sponsor
FoundersPerf's Avatar
Try it now. They are heavy so it won't be cheap going to Canada.
Old 03-11-2016, 01:27 PM
  #123
Can you give me a quote: h1m2n9
Thanks!
EDIT: Just did an estimate on the site and it said 146$! LOL.. That can't be right..
Old 03-15-2016, 12:33 PM
  #124
Former Sponsor
They are very heavy and we only give the option to ship USPS to Canada. We can ship them using FedEx with a cheaper initial shipping cost but then they slam you with customs fees and it ends up being more expensive.
Old 03-07-2019, 07:29 AM
  #125
IROCK1987's Avatar
Car: 1987 Iroc-Z
OK old thread, but I cannot seem to find the answer. I have an '87 Iroc-Z and looking into lowering just the front.
I read that a lot of people are liking and disliking the Vogtland set 959212.
But: wil this lower the Iroc-Z that is already stock lower than the other Z28's and Birds?
Old 03-07-2019, 07:54 AM
  #126
Twin_Turbo's Avatar
Yes
Old 03-07-2019, 08:27 AM
  #127
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Yes it will. I actually just removed my vogtland lowering springs and am interested in selling them. They look good and work fine, I just wanted adjust-ability so I went with weight jacks.
Old 03-17-2019, 07:33 AM
  #128
IROCK1987's Avatar
Car: 1987 Iroc-Z
Thanks, but I live in the Netherlands; probably better to buy them new from Vogtland in Germany.
customblackbird
08-15-2021 10:16 PM
Orr89RocZ
04-25-2016 08:28 AM
sweet_87_iroc
09-25-2015 10:01 PM
gta90
09-15-2015 04:00 PM
Quick Reply: Founders Performance now stocking Vogtland Sport Springs
