UMI Releases New Product: Bump Steer Kit for 82-92 GM F-body
1982 - 1992 Chevrolet Camaro
1982 - 1992 Pontiac Firebird
(also fits GM G-body 1978-1988)
P/N 3060
View website
UMI Performance is proud to release our new P/N 3060 bump steer kit. UMI’s F-body and G-body bump steer kit is designed to reduce or eliminate toe change during suspension travel (also known as “bump steer”). Reduction of bump steer improves handling and straight line stability and enhances overall precision of the steering system. These direct bolt-in kits allow the builder to relocate the outer tie rod end lower than stock (or higher if necessary). The stud taper is designed for exact factory fit for each application and is constructed of 4140 CrMo for strength and durability, no spindle drilling required. The adjuster is 6061-T6 Aluminum hex for lightweight strength and features a hard anodized protective finish. Kits include 6 each of shims in 0.125”, 0.1875” and 0.250”. These race-tested bump steer kits are 100% designed and manufactured with pride in Philipsburg, PA – USA.
P/N 3060
View website
