Why does my car set so high?
1 Post
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
Re: Why does my car set so high?
Looks fine to me. Remember, these cars came from a time where stock height was practical and not SMASHED N SLAMMED to where you have trouble getting over speed bumps.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
here is a picture of mine when it was all stock. looks similar. Other than making sure springs are indexed, it might settle a little as well.
Car: 89 Firebird
Engine: 355 TBI
One reason is because it doesn't have ground effects. Ride height looks to be about right.
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Just had all new shocks struts and springs put in my car, made a huge difference in ride height, I was shocked at first too!!
Yea, that doesn't look that far off stock, you can't see the fender gaps here unless you turn your display brightness way up, but you can see how high it sits. This is an '87 with the stock '87 WS6 springs and stuff (it sits well over 2" higher than my Taurus SHO, which is a suspension used in police cruisers that need ground clearance):
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Take a tape measure and measure from the ground through the center of the wheel to the fender lip. These cars came with "roughly" 27 inch height on the front and 28 inch in the back.
Chuck Haynes
06-29-2003 07:46 AM
86transamws6
05-29-2001 06:30 PM
