Missing something in front of right wheel?
Old Feb 18, 2018 | 05:57 PM
Webnerdnick's Avatar
Car: '91 Chevy Camaro
’91 camaro rs 5.0 305 stock.
i pulled the wheels yesterday to replace the sway bar links. When I was looking around at the front wheel, there appears to be mounting points in front of the front right wheel in the space between the engine compartment and fender. The left side just has a spacing bar that appears to keep the shape of the fender there, but the right is a completely different setup. There is even a pass through into the engine compartment that looks like where’d you route a hose or something. What’s missing?
Old Feb 18, 2018 | 07:08 PM
NoEmissions84TA's Avatar
Re: Missing something in front of right wheel?
A photo would help.
Old Feb 18, 2018 | 08:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
There is a slot in the frame rails on the passenger side to provide access to the idler arm bolts. Generally the plastic inner wheel liner had a tab that inserts into this slot to locate the liner.
Both sides should have small braces to connect the lower portion of the fender to the chassis
DanielRicany
Feb 19, 2018 07:33 AM
Malicious3rdgen
Oct 28, 2013 01:43 AM
zz's z28
Wheels and Tires
Oct 20, 2011 10:43 PM
GTA1990
Mar 19, 2011 02:34 PM
Mark A Shields
Jul 29, 2002 10:27 PM
