UMI Weight Jacks and Moser 12-Bolt Questions
Old 11-29-2018, 06:52 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Am currently going to install a Moser 12-bolt in my 85 third gen. Am also going to use UMI weight jackets in front and rear. Has anyone done this? I need to know how tall the Moser installed center tube piece on the spring perches needs to be.
Old 11-29-2018, 07:02 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
Re: UMI Weight Jacks and Moser 12-Bolt Questions
Is the Moser not built yet? Would you not just set it up like a stock Thirdgen rear?
Old 11-29-2018, 07:08 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Housing is being built. Moser wants to know what height to make center rear spring tube because weight Jack fits inside. See pic:
Old 11-29-2018, 07:17 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Old 11-29-2018, 07:42 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Yep, I'm following....UMI's look pretty similar to my Ground Control jacks. .....this rear I've been getting ready to install is 5/8" off the base. Assuming everything else is to thirdgen specs, that should work. MY jacks portrude down BELOW 0" deck, for lack of a better term, by about an inch. If Moser cuts that tube down to 5/8", is it hollow in there???
Old 11-29-2018, 07:47 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Yes it is hollow. I will have to drill hole for height adjustment.
Old 11-29-2018, 07:58 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.73
Just to make sure but you do know that umi says the rear kit only works with factory and strange rears right?
Old 11-29-2018, 08:15 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Inside diameter of cup will work. UMI verifies that. Height was the issue. Thanks for the heads up. Will call Moser tomorrow and give them the needed height measurement.
Old 11-29-2018, 10:29 PM
COTM Editor
QwkTrip's Avatar
Received 1,849 Likes on 1,265 Posts
Car: '89 Firebird
Engine: 7.0L
My Strange unit is roughly 1.5 times coil wire diameter.
Old 11-30-2018, 01:46 PM
UMI Sales's Avatar
Give me a call at 814-376-6000 and we can discuss.
There has to be a clear hole down through for the jack bolt. Also, I can look on the drawing and check diameters. Our goal is to try it on our in-house Moser but we haven't done so yet.
thx
ramey
Old 01-15-2020, 03:47 PM
Qnitro's Avatar
I just bought the UMI kit front and rear.. I have a quick performance ( with similar to the strange)
Has this been solved?
itsMikey
07-16-2018 03:36 PM
Blowtorch79
05-17-2013 06:47 PM
19doug90
06-11-2010 12:52 AM
87350IROC
03-07-2010 07:36 PM
CustomX
04-22-2003 02:29 AM
Quick Reply: UMI Weight Jacks and Moser 12-Bolt Questions
