car sitting cattywompus - Third Generation F-Body Message Boards
Old 01-13-2019, 09:15 PM
Car: 1991 base firebird
Engine: tbi 305
my car is sitting higher on the driver side. it seems to be the front driver causing the problem .i installed shorter springs recently. im putting together a list of things that might be the cause. please add anything you have run into before.
1)spring upside down
2)clocking ( already checked this and its fine but its important enough to be on the list)
3)isolator mounted wrong or wadded up in the spring pocket
Evilokc is offline
Old 01-13-2019, 10:02 PM
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
Transmission: TKO600
Re: car sitting cattywompus
I actually had the spring sit wrong in the pocket one time. I was SURE that wasn't possible. I'm still not sure how it happened. Yet while jacking the car up to get in there, the pressure/force shifter and heard a giant PING. All fixed.
Abubaca is offline
Old 01-14-2019, 11:33 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
What front springs did you install?
Galaxie500XL is offline
Old 01-14-2019, 04:44 PM
Car: 1989 Firebird
Engine: 5.7 LS1
Did you fully tighten your A-arm bushings with no weight on the tires? If you did they can bind up.
Did you take off your struts? or move your strut mounts? a really bad alignment combination can cause it to sit different side to side.
Did you leave your car jacked up on one corner for a while? These cars can develop a twist.
Is your front and rear sitting higher on one side than the other or is it only one corner or opposite front/rear.
Did you use new isolator or old ones? if the old ones did you make sure they were seated as they develop shape and can cause issue if not clocked the same.
The most common cause is the spring not being positioned into the pocket so that the end lines up with the recess -- I assume this is what you mean by clocked.
Aviator857 is offline
Old 01-14-2019, 04:46 PM
Car: 1989 Firebird
Engine: 5.7 LS1
Also try swapping the springs side to side and see if it moves with the spring or stays on one side.
Check your spare tire area make sure it isn't full of water or something.
Old Yesterday, 06:16 PM
Engine: tbi 305
voitland from founders performance
Evilokc is offline
Old Yesterday, 06:28 PM
Engine: tbi 305
1) when I tightened the control arms the front was on ramps. so there was weight on them.
2) I removed the struts and strut mounts. both were replaced with new parts.
3) I have always jacked my car up by the k-member. its never been left jacked on a single side while I have owned it but who knows what happened to it before I got it. im a little afraid it is torqued. I hope that's not it.
4) the front driver is the highest and the rear passenger is pushed down the furthest.
Evilokc is offline
Old Yesterday, 06:29 PM
Engine: tbi 305
that's a good idea.
Evilokc is offline
Old Yesterday, 06:48 PM
Engine: tbi 305
the pics with my hand are the front wheels. the difference is an inch or so as you can see. the rear also sit different but not nearly as pronounced.
Evilokc is offline
Jono
02-15-2003 01:13 PM
mitch84ta
07-27-2002 01:13 PM
Luther6704
05-25-2002 01:08 PM
91RS5spd
04-15-2002 10:43 AM
JMBoriss
10-02-2001 08:42 PM
Quick Reply: car sitting cattywompus
Advertising
Featured Sponsors
Vendor Directory
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
