Feakin weird problem,and its not the intake gasket!
Old Jul 17, 2002 | 10:10 AM
RS'er's Avatar
I was told I could check for intake gasket leaks easily by squirting carb cleaner around the seal when the engine is running. If there is a leak,I'll hear the throttle increase a little.
Well I tried it and nothing.
The problem is this. At a cold start,even sometimes when the engine is warm,the engine doesnt like to run right. It idles rough,likes to die if you dont give it gas,throttle response is extreemly slow,and when I try to drive it like this,it's like 90% of my engines power is gone. When its in gear and I floor the gas,it bogs down,I dont hear the engine fire,untill I let off the gas then it comes back to life.
All I have to say is WTF is going on with my car? Its been doing this for quite a while and I want to find out the problem so I can fix it.
Only clue I might have is there might be a vacuum leak. reason for me saying this is that somewhere behind the air cleaner I can hear an audible HISSSSS........
WTF is up with my car?
Old Jul 17, 2002 | 10:14 AM
RS'er's Avatar
Oh and BTW I've had it hooked up to a scanner....Everything checks out alright.
Old Jul 17, 2002 | 12:14 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Hmmmmm........ I had the same problem happen not to long ago.......Some how, the spark plug that runs from the cap to the coil had popped off just enough to allow her to run, but like complete a$$. It threw a code however. There was one time the mechanic didn't connect two of my spark plugs, it obviously ran horrible then too. No code on that one though. The only reason I'm kinda pointing out your ignition system is because the hiss you hear behind the air cleaner may be your TBI-which is perfectly normal. If you can deturmine that it's not your tbi making the hissing sound, then you probably do have a vacuum leak. Just be sure to check first and possibly save a lot of trouble 'cause it may be something very simple like a bad wire.
Old Jul 17, 2002 | 12:49 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
If you had a vacum leak it would probably have a hi idle. I would say that it is probably fuel oreiented. It probably isnt getting enough fuel when you give it gas but at idle it is ok. CHeck your fuel filter and/or the pump.
Old Jul 17, 2002 | 04:43 PM
RS'er's Avatar
Fuel system checks out and I got a new fuel filter too.
The thing is it mostly only acts weird when the engine is cold...
Old Jul 17, 2002 | 07:19 PM
Engine: LO3;383tpi
Make sure the vacuum for the thermatic valve on the TBI unit is properly hooked up, or sealed if you have removed it or installed an open element. If you have played with your fuel pressure rescently, it could be the pressure is too high, especially when the engine is cold and is trying to warm up. Check your spark plugs to see if this may be the problem.
Old Jul 18, 2002 | 12:53 AM
RS'er's Avatar
Whats a thermatic valve what does it do and where is it located?
Old Jul 18, 2002 | 01:55 AM
TBI305Camaro's Avatar
sounds like what my car was doing with the fuel pump was going...they also said it checked out fine then one day no fuel at all..then i swapped pumps and it ran perfect.
Old Jul 18, 2002 | 04:18 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Put a fuel pressure guage on there and keep it there. When the car acts up again check it for a drop. Thats the only way you can absolutely rule out a fuel problem.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
