getting fuel for a second or two and then it cuts off
Old Oct 10, 2002 | 02:17 PM
knightjacob's Avatar
I've got an '89 RS 305 TBI. I rebuilt the motor this spring and it ran for a few days and then wouldn't any more. I had a mechanic working on it as a side project, but my daily driver broke down so now I'm stranded so I would like to get the camaro running.
What's happening is that I try to start her up and she cranks and the injectors fire enough for her to start, but then the injectors stop spraying and it just dies. I tried revving it a little bit to maybe keep the fuel flowing but it did the same thing.
What could cause the fuel to be cut off? Any ideas? I could really use any advice you guys could give. Thanks.
Old Oct 10, 2002 | 02:43 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Are we having a fuel pump plague around here or what?
It is most likely the fuel pump but replace the fuel filter first. I know my car had the original fuel filter in it when I bought it with 100k miles so its a commonly overlooked problem but I have never heard of a filter being so clogged that it wouldn't run at all.
Might also be a bad fuel pump relay but I would think that the engine would never run at all.
Old Oct 10, 2002 | 03:51 PM
the mechanic that worked on it said there was plenty of fuel presure and that replaced the fuel filter so that shouldn't be the problem
Old Oct 10, 2002 | 08:50 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
If you have the means, do a data capture during this fuel cutoff event and post the results here. I (and others) may be able to figure out something, if only a lead, from the data.
Oh yeah, one more question. When it stalls, will it restart by turning the key immediately back to start? Or do you have to cycle the ignition off, then back on, start, etc. to get it to spray fuel?
Old Oct 11, 2002 | 06:30 AM
whiteboy's Avatar
I am having the exact same problem as you are. So far I have replaced the fuel filter, plugs, fuel pump relay. My next replacement is the ignition module. I am not getting any codes either. I can also start it right back up after it dies.
JW
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
TA8487
Aug 11, 2015 09:02 PM
