Temperary Carb Usage
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Once I finish building a new 355 for my TBI camaro, I plan on using a 4 bbl TBI from holley, using the stock computer set up (with some minor mods
). The problem is, I have no idea where to start for the timing or VE tables with this new cam, and I don't want any problems breaking in this engine or the flat-tappet cam. So, for the first few hundred miles, I'm thinking of just putting a 600 holley carb on. Do any of you see any problems with this? The intake is already a 4bbl intake, and I figured besides the check engine light, everything should work, including the ignition advancement. So, if anybody sees any problems with this, please let me know!
Thanks,
Carl
). The problem is, I have no idea where to start for the timing or VE tables with this new cam, and I don't want any problems breaking in this engine or the flat-tappet cam. So, for the first few hundred miles, I'm thinking of just putting a 600 holley carb on. Do any of you see any problems with this? The intake is already a 4bbl intake, and I figured besides the check engine light, everything should work, including the ignition advancement. So, if anybody sees any problems with this, please let me know!Thanks,
Carl
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
