Checking TPS Voltage -- How To
Old Nov 14, 2003 | 02:23 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
OK, by request i went and snapped a couple of pics.
sorry i couldn'g get good focus, but you will get the idea.
in picture 1) you pull the plug from the weather pack, and take the covering connector off (basicly opening the plug up)
Old Nov 14, 2003 | 02:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
picture #2
you stick the end of you DVOM in the appropriate wires, just shove them in next to the wire, it will work, trust me
(sorry i am moving, so i couldn't find my DVOM, but i had an anolog MM laying around, so i used it for the pics)
Old Nov 14, 2003 | 02:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i'll answer any questions, to get the correct reading, the neg side of the tester goes on the black wire (far Right) and the possitive side goes in the middle wire.
hope that helps everyone. as Mr_Dude thought you could not do this on the non-adjustable TPS.
Old Nov 14, 2003 | 02:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
2nd pic was kinda dark so i fixed it some.
so you run the motor without TPS??
heh, i guess that would work just to check the sensor output though... matter of fact a analog meter might be better... you will be able to see if the needle is moving smoothly or if it has any jumps to it....
Old Nov 14, 2003 | 02:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok i went out to my car to double check
my connector looks NOTHING like yours.
it doesnt even look like a weatherpack connector... its round.
Old Nov 14, 2003 | 02:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
no you leave it all hooks up, it just shows you the output from the sensor. i didn't even RUN the motor, turned the key to the ON position, and snapped a pic, took me all of what? 5 min to get shoes on, go outside, pull my car into the garage, hook the meter up, snap 2 pics.
Old Nov 14, 2003 | 02:36 PM
Dewey316's Avatar
Car: 1990 Camaro RS
can you snap a pic of your connector?
it should work either way, you just have to get he signal from 2 of the wires.
Old Nov 14, 2003 | 02:58 PM
Nate's 88's Avatar
won't jump if it's bad anyways, it will fall, and an oscilliscope would be ideal to use for that.
Old Nov 14, 2003 | 03:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i no longer have a working digi cam.... if i remember to when im over a friends house, i'll take a pic of it..
my connector is small like, slightly smaller then a dime, and its round.... it has 3 tiny pins in it.
Old Nov 14, 2003 | 03:21 PM
Nate's 88's Avatar
3 tiny pins = reference voltage, signal voltage, and ground.
Old Nov 15, 2003 | 12:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Anybody have a voltage number to set the TPS to ?
The Chev FI book I have just says <1.25... seems a bit vague as compared to TPI TPS specific voltages
Like so ?...
Old Nov 15, 2003 | 12:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it should be set to .54v closed, and should get above 4volts open
Old Nov 15, 2003 | 01:19 PM
Nate's 88's Avatar
yep, just shouldnt read 0 or 5 volts.
Old Nov 15, 2003 | 02:18 PM
deadbird's Avatar
Engine: TPI 305/ v6
Thanks bud. At least I was pretty close
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
