LO3, info
Old Feb 14, 2004 | 08:22 PM
NEEDforSPEED's Avatar
LO3, info
whats the bore and stroke of a LO3 TBI
or tell me every thing you can about the LO3
i tryed searching here and on the net, i didnt find anything thing to be useful
Old Feb 14, 2004 | 10:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A lot of the info is on the Tech Data on the homepage at www.Thirdgen.org
The bore is 3.735" and the stroke is 3.48.
The heads are 58cc chambers with crappy swirl style intake ports.
The valves, AFAIK, are 1.84"/1.5"
The stock intake is aluminum dual plane.
The TBI bores are 1-11/16" (I don't know the factory PPH of the injectors.)
Exhaust consists of iron manifolds into a 2-1/4" y-pipe through a 2-1/4" cat, and 2-1/4" all the way back to the muffler.
That's all of the basics I can think of that aren't on the home page.
Old Feb 14, 2004 | 11:34 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Compression is 9.3:1, uses a roller cam and lifters. Stock net horsepower is 170 @ 4400 and torque is 255 @ 2400. Some stock intakes are cast iorn. Responds like any regular old small block when it comes to mods. Should have 40 lb/hr injectors. Base timing is 0*. The link below will give you much more info.
http://www.goingfaster.com/spo/spo_t...y_central.html
Old Feb 22, 2004 | 06:11 PM
does anyone know the thickness of cylinder walls ?
Old Feb 23, 2004 | 09:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i dont know the max thickness, but i do know the max over bore is .060"
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
