Engine Compression
Old Jun 1, 2004 | 07:17 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Engine Compression
Im sure its on this site somewhere but I cant find it. and I cant find my manual either.
What is the compression rating for the 305 TBI in 1989.
I went to indiana this weekend for the 500 a friend lives up there, any ways on the way up I fouled a sparkplug and so we decided monday to change them out in his garage, and do a compression check. This is the numbers I got
#1 145
all others were 149-152 PSI
This seams real high for a stock motor, and it should be a stock 305 with 190k miles on it. Oh if it matters it is a 700r-4 tranny.
Old Jun 1, 2004 | 10:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The stock compression ratio is 9.3:1. It is listed in the "new to TBI" sticky at the top as well.
Old Jun 1, 2004 | 11:30 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
thats not real high, actually thats about right.. well... pretty good considering the mileage. I dont know what these things got for psi numbers stock but i can tell you my 305 .030 over with a big cam and low compression (8.8:1, its 10:1 now) did about the same as what yours did and my engine was fresh at the time
Old Jun 2, 2004 | 09:27 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Thanks for the help, I knew it was somewhere on this site, LOL there is a formula is there not to take the 9.3 to 1 to get what the psi rating is for each cylinder right. If so what is it.
Old Jun 2, 2004 | 09:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
there is really no way to get that, the cam plays a major roll in effecting the cranking pressure. You could use a DCR calc, and figure hte dynamic compresion, then find the total volume in they cyl. at the point the intake valve closes, then figure how many PSI would be created at a given compresion, for that amount of air, in the ammout of space left. not persay an easy task.
I wouldn't worry about those numbers, you are consistant across all 8 cyls, that is more than most poeple with that many miles can ask for.
Old Jun 2, 2004 | 09:43 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Yea im not worried about the numbers, I am trying to figure out if the engine had been swaped/rebuilt since the car was new, to my knowledge and reasearching the history on the car the engine is stock and has never been taken out, I have rebuilt the tranny though. I was kinda expecting to have to rebuild the engine sometime in the next year and from the looks of those numbers unless I have something break I should be good to go for a good while. I use no oil inbetween changes with 10w40, I've had the car for 5 years and have put the last 80k on it.
Maybe by the time the engine goes down I can afford to put in a LS1.
Old Jun 3, 2004 | 03:30 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Chech this out...
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Some GREAT info about your specific car there. Heck, I thought my car came with the 2.73's just like everone elses but I looked a little closer and saw it was actually 3.08's
Bruce (90RS305)
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
