Possible for....
Old Aug 6, 2004 | 11:10 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
Possible for....
around 425chp give or take from a tbi from any kindof setup? I just got an engine (block and crank only L98 350) and will be going to the machine shop this winter. I was wondering what kind of combo to run if possible, will the holley unit handle that much power? I would like some ***** in this engine and would like something different with the tbi just so that I can say "Its a 350 with a TBI" The thing im having trouble with is how to select the best combo of parts, or should I just ask the shop I will be taking the engine to?
Old Aug 6, 2004 | 11:20 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
get a hold of shiftycapone on here he has some good ideas with the tbi and hp
Old Aug 6, 2004 | 11:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What is the budget? That is the ultimate factor in how fast you can go, at least, reliably.
Old Aug 6, 2004 | 11:37 PM
novadk13's Avatar
not sure how much I want to spend? I dont really want to spend more than 1800-2000 on just the block, then wait a few months for the rest heads around a grand for both, and few months later for the cam, rockers, pushrods, and intake. Lastly will be the fuel delivery, prob just use the stock tbi for the first few drives. The place Im thinking cost 30 bucks per cylinder bore, and 170 for a crank regrind if I need it.
Old Aug 9, 2004 | 11:53 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have never messed with a 400hp TBI set-up but r90camarors has. I think he is close to the limit of the 670 unit on his 383. When you want to get to those power levels and stay TBI, you need to look into the 4bbl set-up.
the blue one
Exterior Parts Wanted
Feb 15, 2013 06:06 PM
Dscott
Jan 18, 2013 12:00 AM
bonesbrakr
Apr 28, 2012 08:30 PM
Willsmith305
Members Camaros
Mar 13, 2012 05:08 PM
