roller or hydraulic???
Old Jan 30, 2001 | 09:06 PM
chevyboy07 91's Avatar
Do the L03's and L98's have roller cams or hydraulics? B/C I want to do the LT1 swap in and know those are roller cams. But, I don't want to have to buy lifters for the roller cam (if the L03 isn't already a roller).
Also, can you run a hydraulic cam w/ roller lifters and vice-versa????
Old Jan 30, 2001 | 09:25 PM
NJ SPEEDER's Avatar
the lo3 came with a roller. you gotta keep us posted on the results of the swap. a lot of us are interested in trying this out.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jan 30, 2001 | 10:08 PM
how 'bout the vise-versa part??......any takers????
Old Jan 30, 2001 | 10:26 PM
Guest
Guest
Posts: n/a
Cam profiles are unique, so no you cant mix and match. In short:
Roller has a flat surface, made of steel
Hydraulic has a tapered surface to spin the lifter, made of cast iron
And so someone doesnt get technical on me... the taper also pushes the cam towards the back of the block.
[This message has been edited by madmax (edited January 30, 2001).]
Old Jan 30, 2001 | 10:56 PM
Basett Racing's Avatar
Madmax is correct. Always use the kind of lifter that is designed to go on the kind of cam you are using. ROLLER lifters, are usually ok to reuse if the engine is just not totally caked up with oil deposits due to those 20,000 mile or more intervals between oil changes. If your lifters all roll freely and just throughly clean them and they should be good to use. Just as a footnote - Its not a good pactice to run new lifters on an old HYDRAULIC cam. I've seen people do this in the past, but it always results in a wiped out a lobe or two in a very short period, filling your engine with fine abrasive metal shavings, putting bearing life on the path to an early retirement.
I would recommend going with the Hydraulic roller personally, I'm planning on doing the same thing to my L03 after I get finished putting the 383 in my 82 Z28 (My current project). If you go with the LT1 cam, keep us posted, I have one of those that I am thinking of running myself.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
