Ignition
Car: 1987 Camaro
Axle/Gears: 4.56
Ignition
I have a 87 Irock that doesn't start. When you turn the ignition it get fuel ,but the ignition system is not throwing off a sperk what could it be.
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Re: Ignition
If you haven't already you need to check to see if your distributor cap is making good contact and it could also possibly be coil failure but that is rather rare for these cars. Also you need to check for good voltage to the coil and dist.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
