Where do the bolts and studs go ???
Old Apr 15, 2007 | 02:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
The intake manifold, I know some are studs (for certain brackets) some are bolts, I took it all apart almost 2 months ago and now I forgot what goes where. Got the factory manual, however for some reason it's one of the GM sketches that doesn't make sence at all.
Description i.e. driver side front to back .. passenger side front to back... most helpful, pictures would be even MORE helpful.
Do some of the brackets go underneath actual bolts not studs ?
Actually, is it even necessary to put all brackets back on ? Last time I did this I don't even think I put the bracket "clamping" the fuel lines back on. What I'm saying is, can I leave the brackets out, and just bolt the manifold back down with just bolts ?
Old Apr 15, 2007 | 11:38 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Where do the bolts and studs go ???
If I remember right, there are only two studs. One goes on the 2nd hole right side front for the harness bracket. The other goes in the 3rd hole on the left side for the vacuum line to the booster.
The bolts for the engine lift bracket, on the right rear go on top of the bracket (bolting the brkt. down).
HTH
Old Apr 15, 2007 | 11:41 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK I see, so basically I CAN get away with not using any studs what so ever, and even not use the brackets, correct ? For a "cleaner" look that is.
Old Apr 15, 2007 | 01:29 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK I see it now, the bracket with the vaccum line and connectors (for the dizzy right ?) has to be on, does that one use bolts or studs ?
Also, the bolt hole next to no.3 runner, it goes all the way into the manifold, right through, what bolts on right there ?
Last time I did this I just had to change the gasket, this time I pulled the engine and had to transfer parts right and left from one engine to the other, that's WHY I now have these questions, it's all apart.
Old Apr 15, 2007 | 04:36 PM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
On my L05 the drivers side front most bolt is a stud for the alternator support bar and 4th one back on the drivers side from the front is a stud that, on my engine is not used for anything.
Old Apr 15, 2007 | 06:34 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Alright, thanks.
Does anyone by any chance have any pictures ? Now that I'm more awake, I remembered that I need to hook up the bracket that holds the throttle cable assembly etc. So if anyone has pics of left and right side of the manifold installed, I would appreciate if you could post them.
I found this pic, but not sure how accurate it really is
http://memimage.cardomain.net/member...814_3_full.jpg
Old Apr 15, 2007 | 07:30 PM
Engine: L05's
Here is how my L05 caprices are set up
useless stud circled in red
Throttle bracket is bolted to the rear most intake bolt and that bolt that it shares with the coil
AC brace uses a studded bolt but its not an intake bolt
Old Apr 15, 2007 | 11:15 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
So the only thing I really have to be concerned about, i.e. only thing that NEEDS to go with the intake manifold, is the throttle bracket.
Old Apr 16, 2007 | 04:47 AM
Engine: L05's
Yea, but the back lifting bracket has spot where the EGR solinoid mounts to it with a tiny little bolt. I dont guess it would hurt anything if it wasnt mounted there. It would be best to keep it from flopping around somehow though, to keep from breaking one of the vacuum lines.
Old Apr 16, 2007 | 09:33 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmmm
Old Apr 19, 2007 | 02:28 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK, hmmm I now have a bolt hole on the driver side, in the middle, and it goes right into the intake manifold, right through, what the heck goes right there ?
Bought a set of new intake bolts, well had to use some of my old ones instead, due to the fact that the threads are a little bit worn out but mostly because these new bolts are SHORTER !!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
