Throttle Body Spacers?
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: Throttle Body Spacers?
IMO.. the best investment would be a VAFPR and RBob's EBL, learn how to tune it will be better then any spacer.
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Its worth it.. But then again its not. If you are going to throw in a TB spacer and thats it, you wont notice very much. What you Need to do if you havent already is the Ultimate TBI Mods's That are at the top of the TBI Forum/Section. and throw in that spacer. That will give you some results.
Howevere that EBL thing is new to me, Guess I gotta check that out!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id avoid the spacer mainly because of the TV cable geometry. If thats off, it can ruin the transmission.
Car: 1991 Camaro RS
I Made my own out of Heat Resistant Plastic. My Father got some from the Mill, we made our own slides for the snowmobiles, And they havent worn very much in the psat 3 years. Anyway I Have a 1/2" Spacer and it didnt Change a thing. If you had anything Bigger than 3/4" inch I think You would Change the Setting of the TV.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
