How do you clean EGR Valve?
Old Oct 12, 2001 | 12:33 PM
88camaro305TBI's Avatar
nt
Old Oct 14, 2001 | 01:03 AM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Try using SNOW BOWL toilet bowl cleaner. The stuff also works on rims.
Old Oct 14, 2001 | 02:42 AM
ChevelleCLM's Avatar
Relocate to nearest trash recepticle, and replace with a block off valve
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. TBI w/custom harness and prom best 14.5@90
Old Oct 14, 2001 | 12:31 PM
Vader's Avatar
Do not use any solvents on the valve. Most EGRs have a positive or negative backpressure pilot valve in the diaphragm housing, and the rubber used on the pilot valve seal is engineered to resist high heat, not solvents. Damaging the pilot valve can render the EGR useless.
Clean the pintle and seat areas with a stiff wire brush and a soap and water solution only. A steel-bristled soldering flux brush works well for this.
If you're thinking about removing the EGR and running without one, that's fine if you don't mind the retarded timing and lower net power. Check the archives for details.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 15, 2001 | 02:39 AM
Guess I got to agree with vader on the removal, but they sure are ugly. I do not seem to have any problems with my block off plate though. I have only Knocked out 1 time and the computer backed the timing off and my car was overheating?
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
