Lt1 cam Question?
Lt1 cam Question?
Putting in a camshaft very soon.....and on the timing gear...should i put the timing gear....should i leave it a 0 degrees....most chain setups have like a 3 adv or 3 neg timing....also i've heard of ppl advancing there timing......is this done by rotating the distributer?
thanks
nathan
thanks
nathan
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you retard it it just moves the power up in the band, but you lose a litle down stairs. I'd say put it at "0" for drivability, that's where mine is and it works great. When they say advance the timing, yes it means to set the initial up by turning the dist. I'd say set it at 6 degrees, it works for me.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
