What do I need to change?
Old Oct 30, 2001 | 09:17 PM
Risk81's Avatar
I found a 3.42 rear end with Posi and disc brakes. I have a 5 spd. 3.08 rear end with drum brakes, Do I have to change the master cyclinder and brake booster and if I do where would I get a replacement one? Thanks
Blue 1989 TA
305 TBI
5 Spd.
Headman Headers with smog delete
Hooker cat-back
MSD coil
Old Nov 8, 2001 | 09:37 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Swapping my one-legged 3.08,drum brake rear for 3.73 Posi,Disc rear next month,so I've looked into this.
The Master cylinder and Proportioning Valve are different for the four-wheel disc cars,so you should get both.I don't think you'll need to touch the booster.
I plan on adding a Wilwood Adjustable Prop Valve in the rear line as well, for fine-tuning.(only about $40)
I bought a rebuilt master at local auto parts store.Haven't gotten prop valve yet, but will probably yank that from the wrecking yard, and order the adjustable valve from Summit.
Hpoe this helps-
-Rich-
Old Nov 8, 2001 | 10:47 PM
Risk81's Avatar
Thanks man
[This message has been edited by Risk81 (edited November 08, 2001).]
billybob6110
Feb 11, 2016 10:41 AM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
