Good stuff to sell and I need to buy!
Car: 91 Red Sled
I talked to Dirk last night about some members and I then brought up the classifieds being down. He showed me what they are working on. It's going to be a new format so it might take a little longer.
Ebay and www.car-part.com is always good for used parts.
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yep, I've seen all that on ebay at one time or another. Just need a little honesty and a credit card, and you'll fit right in at ebay. I miss the classifieds though. I like being able to solely deal with this crowd.
Ford red 1991 Formula 350. ROH 16in wheels, 1998 Grey Leather, street/strip 700r4 2400 stall, EIBACH springs, Strut tower brace, Poly Bushings
3.73 SLP POSI, 26 spline Moser Axles, mid SLP cam, grear drive, SLP runners, 24# injectors, Taylor wires, Accel Coil, Accel Ignition, B&M Megashifter, K&N conical, AFPR, SLP 1 3/4 coated shorty headers, 3in cat, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 180 stat, SSM SFC's, SPOHN lower control arm adapters, custom burned prom, Hotchkis Lower control arms, Aluminum Driveshaft, ported upper and lower, q-logic kick panels.
Instant Messenger JMatlock88
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by fast_broker:
I have never sold anything on Ebay. Is it worth my time for ProJection ssytems, intakes, heads, etc???</font>
Lots of people just fall for those words.
LOL? I might just use the Holley TB and GM pod I have without an IAC, as the ProJection's don't have one. I don't need any frigging idle control for ATCO, do I? I could hook up the kicker solenoid from the ProJection kit, I suppose, to just a switch to MANUALLY raise the idle speed when cold or to raise it a lot for staging...
Firechicken86
Aug 12, 2015 10:07 PM
