Center TBI?
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Center TBI?
Got my Professional Products single plane intake in today and soon discovered that the adapter plate I was given with my ECM is the wrong size.. so I'm going to have to drill some new holes in the intake- oh well.
Since I have to do this I was wondering about centering the TBI on the intake while I'm drilling and cutting. Should the TBI be centered or is it mounted off-center for a specific reason?
Centering would really work out in my favor, as I have to take a dremel tool to the mouth of the intake so they don't obstruct the flow from the throttle bores and the least amount of material is in the center
Oh, and it looks like my hood's gonna get cut as well
Linked the picture from facebook so let me know if it doesn't show
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Here is the intake as it sits (pics below) it would be a little easier for me to put it in like this, now that I think of it- much less drilling but a little more dremel-ing.
But of course, I'm not looking for the easy way out. I want it to perform the best it can and if centering is needed for that, then I will do it
Re: Center TBI?
Those adapters don't look so bad on a dual plane intake but sure looks wrong/dumb on that intake! You could get the right adapter? Also save 1/4 inch by using a 1/4 inch transdapt steel instead of aluminum. Be careful to seal it up good and use studs lock tighted in or short bolts that don't go through adapter and hit intake causing a HUGE vacuum leak, before you install it.
For clearance the caprice TBI air filter was the lowest I have seen for TBI.
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
I think you're right Mark. I really don't want to blow $50 on a simple plate but in the process of modifying my current plate I'll probably spend time working on it that could be spent landscaping and making the money to buy a better product.
Not to mention, the 1/4" lower height will help with the already f***ed up throttle linkage geometry
Re: Center TBI?
I think they are only $35, you could recover that from the one you have...
But the 1/4 plate steel are no where near as true! Use O2 safe gasket sealer both sides to intake and try to get away with none to TBI, or thin layer both sides as well, let it dry overnight. Pay special attention to studs or bolts not protruding through adapter and causing vacuum leak! Not to mention gouging aluminum intake!!!
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Nope, They're around $44. And you're right, I might be able to get $30 or so from the one I have now.
As per the gasket sealer, I have some Ultra Copper RTV I bought for my head gaskets- that should do the job.
Car: '90 RS
Engine: 305 TBI
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Well whatdya know, I have a tube of black RTV in the basement. Definitely saves me a trip and a few bucks
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Decided not to buy another one and just drilled my current adapter and intake manifold. Pictures will be up in my build thread soon.
My question now is, do I need to buy a gasket for both the adapter to the intake and TBI to the adapter, or can I just use the black RTV to seal everything up?
Re: Center TBI?
Yes use gaskets! I looked on the black RTV I have here and it says not to come in contact with gas! So it must have been differant gasket sealer I used on them as they ran for years with no issues.
If everything is fairly true, gaskets alone should do the job, but I have had so many vacuum leaks with those metal adapters.
Since your back to a straight true aluminum adapter probably no need for gasket sealer. I have never had issues with those.
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
That all being considered, I'll try to pick up some new gaskets today so I can start finishing the intake assembly. The last step will be fitting the IAT sensor to the intake manifold
Re: Center TBI?
IAT goes in air cleaner. MAT goes in intake manifold. They are handled toatally differantly in ECM... what was the ECM designed for?
The sensors themselves read the same temp, same as a CTS. But the way the ECM uses the temp is differant.
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
I would put the IAT in the air cleaner but due to the air-gap style of the intake manifold, the readings would be off. I read a thread a few weeks ago on putting the IAT in the intake for a more accurate reading but can't seem to find it. I believe dimented24x7 wrote it, but I could be wrong
The ECM will be able to handle it just fine, as I'm running EBL Flash
Re: Center TBI?
Why?
IAT reads the temp of air coming into the intake.
MAT reads temp of air in intake which is differant because the fuel coming from TBI is evaporating, and on other manifolds the intake itself is heated by exhaust crossover and coolant passages.
What it boils down to is the way the ECM is designed to use the temps it gets for calculating fuel.
Since you have EBL just ask RBob what the setting in EBL should be for the way you have the sensor mounted.
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
Why?
Hopefully I can make mine work without having to convert to MAF...
Re: Center TBI?
No reason to need MAF, just that IAT and MAT are 2 differant temps and the way the ECM uses those temps has to be right. You can change a MAT to IAT or IAT to MAT but ECM needs correct info.
Just ask RBob and he will show you what needs to be done with EBL.
Car: '90 RS
Engine: 305 TBI
Re: Center TBI?
TBI cars don't have MAT, just IAT and CTS. I'll see how it runs with my current setup and programming before I bug him. Who knows, I could get lucky and not have any problems
Glowsock
Sep 11, 2015 11:09 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
