Code #53 Help!..
Old Jul 8, 2014 | 05:41 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
Transmission: 5-SPEED
Code #53 Help!..
Isn't this showing VATS error? Well, the security light turns on and shuts off in 3 sec. I'm confuse how the injector connectors are not getting signal to fire both injectors, does VATS control the ecm to fire injectors am I right?
The car would crank, but how did i get a code 53?
I'm really stuck on this injectors not firing, but the car is getting spark. Can this be a faulty ecm?
To someone out there who has the same issue like mine, please help me to bring this car back to life
Old Jul 8, 2014 | 04:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code #53 Help!..
A lack of the VATs signal to the ECM will cause the ECM to not fire the injectors.
Since the security light works OK, and the engine cranks, either the VATs module output to the ECM died, or the ECM is bad.
RBob.
Old Jul 8, 2014 | 09:51 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
RBob.
Where is the vats module located, how do i go about testing this? as well as the ecm?
Old Jul 9, 2014 | 12:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The VATs module is attached to the front side of the defroster duct. Wedged between it and the firewall.
Best way to test is with an o-scope, look at the signal on pin B6 at the ECM. Should be a 30Hz square wave, 5 volts.
A DVM on the DC scale should show about 2.5 volts.
RBob.
Old Jul 9, 2014 | 11:20 PM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
RBob.
Alright, I've tested ecm and vats module. Resulted 2.8v on vats module and 4.80v on ecm which they're okay. Could there be a broken wire somewhere?
Well, I checked for power with test light on (red) injector connector but didn't get any power, as well as for the (blue) no power on ground as well.
But for the other injector seemed to be fine because i get power and ground from there.
I wanted to trace this red wire to check if its broken, but i can't seem to find where is this connected to?
Old Jul 12, 2014 | 03:41 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
"Update" Passenger side injector is getting signal and would fire gas if i probe the (purple/white) wire connector from ICM.
I don't know what's wrong with the driver side injector, it does nothing at all? It doesn't get signal at the inj connector?
Old Jul 13, 2014 | 07:08 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
I switched the connectors, now I'm not getting any power on both inj. connectors while key is on and no ground on ecm as well?
Old Jul 19, 2014 | 06:21 AM
Cam_RS's Avatar
Car: 91 CAMARO RS
Engine: 5.0 TBI
I got life!! Car starts and idles. Turned out to be the tooth of the fuse box connector was a bit loose. Everyone
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
