305 TBI gas mileage?
Car: Firebird
Engine: 305 tbi
So I’m hearing a lot of people say they’re getting mid to high 20s mpg, in their 305 tbi cars. Mines a 1991 firebird with a 305 tbi, it has 145k miles on it and has brand new injectors, fuel filter, completely rebuilt tbi, spark plugs, ignition wires, ICM, distributor cap & rotor. Mine gets consistently 14-16 mpg. I’ve never gotten more than 16 and never got less than 14, so how are people getting these higher numbers? The majority of my driving is high way driving too.
Re: 305 TBI gas mileage?
Got 2.73s with overdrive doing 55 on highway? I don't know what my car got stock, when it got to empty I filled it I'm sure some inflate numbers too.
1. What is the cranking compression of all eight cylinders?
2. Restricted exhaust (Plugged catalyst, crushed pipes, damaged inner pipe wall, etc.)
3. Brakes dragging? (Stuck caliper pistons, seized emergency brake parts, etc?)
4. Ignition timing set properly?
5. Hilly terrain? Hills will kill fuel economy.
6. Cruise control working properly?
7. Tires inflated?
8. Transmission has four gears + converter lock-up? Or five manual gears?
9. O2 sensor failed?
10. What does the scan tool show for short- and long-term fuel trim?
11. Knock sensor retarding timing?
12. Coolant temp sensor failed?
Car: 89 Firebird
Engine: 355 TBI
Even with 3.73 gears I'm getting over 25mpg out of mine. Is the car running sound?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Everyone is going to have different values, relating to your driving conditions. If i purely drove freeway, my 350 with EBL can get 28mpg cruising at 60mph. Yet if i drove at 85mph same car, it would dip VERY fast.
If im WOT every street light i get 6mpg...
My Average for 90% city 10% freeway i get 11-12mpg. (350 TBI that is)
Car: 1983 G20 Chevy
Transmission: 4L60
Axle/Gears: 10 Bolt 2.73 Open
Interesting subject, and some interesting results.
I'm one of those nuts that keep track of every gallon of gas he buys. No, I don't always fill up at exactly the same pump...there are some MINOR variable. This is mostly in town, a few highway miles in there. And it's almost always driving a little faster, and accelerating a little harder from every stop than I ought to. There are NO economy runs on this page...no all highway, cruise control set, getting the best mileage I can runs.
So of the lowest averages are from a trip to the drag strip, or the Woodward Dream Cruise (4 hours of idling through traffic), or short fill-ups, and the next one is unusually high. Let me save you the trouble...that's an average of 18.1 for all of those.
Car: 1983 G20 Chevy
Transmission: 4L60
I actually kept a log on Fuelly.com for my 2012 Titan when I owned it. Logged more than 15,000 miles worth of driving. That included everything from towing heavy trailers, often loaded to near payload capacity, to driving into the mountains, to daily stop and go traffic. My highway speeds are higher than most as well, ranging from 75-90+ mph.
http://www.fuelly.com/car/nissan/tit...titansv/134758
I have not kept a log on my current car, but the car has its own log and I have stayed at an ECM calculated 19.6 MPG for the past 24K miles, since I reset the total accumulative. The ECM was accurate enough that I have not kept a log outside of what the car shows because it was accurate within +/-0.2 mpg the times I checked. 2011 M56S weighing 4,400 lbs empty making close to 500 HP at the crank. With myself and 2-3 passengers I am often rolling down the road at over 5,000 lbs.
Car: 89 Firebird
Engine: 355 TBI
My carbed, cammed, vortec350 in my last trans am avg 16-18 mpg and the torque converter wasn't even locking up.
When my white 91RS was a 305 TBI 700r4 w/2.73 gears 30+ was easy on the highway. Car was in ideal state of tune, good tires properly inflated, good alignment, all maintenance meticulously done. Friend of mine didn't believe it was possible to get 30 mpg in the car. He was with me when I filled the gas tank at the same pump and the whole 440 mile round trip. It was almost all interstate. He was with me when I refilled the gas tank with ~14.4x gallons of gas. The RS odometer was within 1 mile of GPS on mileage covered.
Made a believer out of him that my white RS could get 30+ mpg.
The white RS could get 32-33 mpg consistently. Some of it is driving style. Easy on the gas
My 91 RS Convertible can only hit 28.5 mpg, same maintenance etc. I suspect the transmission in the convertible slips just a hair.
Car: 1988 Pontiac Firebird Formula
Engine: 305 TBI, Hedman shorties
Axle/Gears: 3.23, non-posi drum
I get between 17 and 21 consistently. My setup:
88 Formula
700R4 trans, 2.73 rear, new tires and recent alignment
stock manifolds, factory exhaust piping with cat delete and SS transverse turbo muffler
305 TBI that never burns oil and is mostly stock with peripheral mods:
- MSD wires
- new cap, rotor and coil
- new plugs gapped at 0.045"
- 160 degree thermostat
- Spectre performance extraflow air cleaner element and lid
Most times i get about 230-250 miles out of a tank with a mixture of town and highway driving.
If I spend the day cruising backroads around 55 mph, I've gotten as much as 300 miles out of a tank.
88 Formula
- MSD wires
1992 Firebird convertible
305 TBI w/ 700R4
2.73 open rear
Mostly city
13.3 MPG
I drive like a little ol' man and the car is bone stock, runs excellent and is very well-maintained. No hills either (I live in Florida)
Kinda sucks
305 TBI w/ 700R4
2.73 open rear
Mostly city
13.3 MPG
Kinda sucks
It's good discussion for anyone curious. I was actually gonna create a "post your MPG" thread but this seemed more engaging.
Car: 89 Firebird
Engine: 355 TBI
89 L03 TBI. 15psi spring kit. 160Thermostat. 3.73 Posi. 700R4 w/ Shift kit+corvette servo. S10 Torque Converter (maybe 2300RPM Stall) Open Element. Open Cowl Formula Hood. 3in flowmaster cat-delete exhaust system. Custom Chip. 91xxxmi. Over 25MPG have done closer to 27 on highway trips but I don't daily drive it most trips are on highways going to shows.
Car: 91 camaro rs
Transmission: 5spd
I purchased my 91 rs from dad in Florida it has a 305 with 5spd I drove it back to Virginia almost 1000 miles at 70 to 80mph and averaged 26mpg it also has 250000 miles on it
Every time I drove my 91 it was empty pretty fast, $20 got me a day ( beating the **** out of a 200k mile engine )
