one cylinder not firing
2007 Pontiac g6 4 cylinder, the third cylinder is not firing, new plugs, swapped plugs/coils packs, checked wiring and voltage, swapped fuel injectors, check wiring and voltage, problem stays with the cylinder, looked down into it and the head is slugged up and wet.
Re: one cylinder not firing
Good Luck with it .......
happyhapka
06-18-2017 09:39 PM
happyhapka
06-18-2017 07:53 PM
