Open elements?
Old Feb 25, 2002 | 05:16 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Open elements?
I'm in the process of doing some tbi mods and wanna one what kind of flat base open elements people are running without any clearence problems. I'm gonna probably order something from Jegs or Summit and wanna make sure that I get something that is gonna work the first time. I like look of the Edelbrock Elites. Anybody use one of those?
Old Feb 25, 2002 | 05:24 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Moroso Chrome 14"x3" Flat Bottom Racing Air Cleaner,Part#65911.Bought at Summit for $47.99
It clears the linkage and the hood with the Edelbrock Performer TBI Intake Manifold, which is 1/4" taller than stock.
(TBI air cleaner spacer removed)
-Rich-
Old Feb 25, 2002 | 05:41 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I'm using the Mr. Gasket one, I got it at Advanced Auto Parts
Old Feb 25, 2002 | 05:48 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Ive got a summit one.
Andrew
Old Feb 25, 2002 | 06:00 PM
NJ SPEEDER's Avatar
the moral of the story is that any 14x3 flat base air cleaner will work great. so go to your local parts store and buy tehfirst 14inch flat base you see.
later
tim
Old Feb 25, 2002 | 06:18 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
What open air elements can be used w/out the spacer besided the MR. Gasket one? I have an edelbrock one, and i have to use the spacer, which defeats the purpose of my injector spacer and shaved throttle ridges.
Old Feb 25, 2002 | 06:24 PM
Tas's Avatar
Tas
summit has their house brand, PAW has theirs, weiand, moroso,... lots of them. Just look for "flat base" or "non-drop base"
www.summitracing.com
www.pawinc.com
You can get just the base from summit for your elebrock for around $10 last I checked.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
