posted this a while back and noone answered..perhaps?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
91 bird 305 tbi vin code e.....................in tank fuel pump......anyone know the stock pressure and flow rate of the pump? also what would you recommend as far as a replacemement keeping in mind i have a 150 shot of juice to install.........what psi and flow rate would do the job and who makes the best drop in application?
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I think I read in a Chiltons repair manual that the 305 tbi had 9-13 psi. I'm not too sure about these numbers, cause the whole manual was filled with mistakes.
Turbocity.com sells a high output replacement in their TBI section, if you're worried.
I'd have to say that 150 shot would be marginal, even if the stock pump is in good condition, newer.
I've heard that the stock pumps limit is about 125, for nitrous.
1 Post
Car: 91 Red Sled
Don't gamble with the stock fuel pump and N2o. Spend the $98 for the 255gph Walbro in-tank replacement pump. The last thing you want to do is have the stock pump drop the fuel pressure dangerously low and blow up the motor!
no definitely not leaving the stock pump in there thats why i posted this ..........a walbro pump you say? who sells em
also do i have to get a tbi pump? i know im running 16psi at the tbi now...i wasnt aware that this is also the psi of the pump...i thought the regulator took care of that.....if this is the case wouldnt a tpi pump have alot more pressure and not be suitable for a tbi setup?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The FPR should take care of the extra fuel by just routing it back to the tank to maintain your pressure unless it flows more than the regulator can handle, in which case youll have a pressure buildup.
ok so can somone direct me in a direction of a pump with adaquet flow rate,psi, reliability and price? i know i know i want it all hehehe
now thats sweet .......... thanks alot dimented doesnt get any easier than that
Fronzizzle
03-18-2019 08:29 PM
