Vader-->coolant temp sender resistance
Old May 11, 2002 | 09:53 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my gage shows that i go to like 230° when idling and i'd like to know if that's accurate. i know that at 100F the sender is supposed to have a resistance of i think 1.5kOhm (not sure on exact number, book's not here) and at 260F it's 55Ohm. If i make a temp vs. resistance graph, put these two points on and connect them with a line, should i be able to get a resistance reading off the sender and see what temp it correlates to with the graph? or is the resistance growth/decay curve non-linear? and if it's not, do you know what resistance i should have at 220F? thanks.
Old May 11, 2002 | 10:24 PM
Jza's Avatar
Jza
Also, just so you know for future reference, read this:
https://www.thirdgen.org/techbb2/sho...572#post663673
Old May 11, 2002 | 11:01 PM
Car: '87 Camaro LT
Engine: 355 L98
thanks. and i won't page anyone specifically any more, scout's honor.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
