compression question
Old May 27, 2002 | 09:32 PM
89WS-6's Avatar
Yeah, I have got a compression question with some heads. Remember that I have a 350 4-bolt IRON block, not an LS1. But I haven't purchased any pistons yet so we can keep that out of mind. But I want to run N/A so I will do high compression. What cc head should I go with? 64cc or 76cc? If I went with the 76cc, what kind of compression would I be looking at? Thanks all
Old May 27, 2002 | 09:37 PM
BAK12484's Avatar
well if you are planning on running a high compression motor, obviously you should choose the 64cc and forget about the 76cc.... then get domed pistons if you want even higher. Just throwing out a guess, but w/ 76cc's you'd be looking at around 8-9 CR
Old May 27, 2002 | 09:38 PM
Jester's Avatar
It's impossible to say without more information. you need to know the piston dish/dome volume, deck hieght, and head gasket thickness to work any of it out.
As a generall rule tho, a smaller chamber is better. Just be sure you get pistons that will keep compression to a reasonable level with it.
Old May 27, 2002 | 09:44 PM
89WS-6's Avatar
So maybe with a 383 in the future, I would want to go with the 76cc's, because with that longer stroke, it will raise comprerssion in itself. Also, I plan on some high compression, forged pistons by either TRW or Ross. thanks,
Old May 27, 2002 | 10:42 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well:
Bore = 4.03
Stroke = 3.48
Head vol. = 76cc
Valve reliefs = 2cc (Flatop Pistons)
Deck Height = .025"
Head Gasket = .040" Thick
Head Gasket Bore Dia. = 4.166
Comp. Ratio = 8.89 to 1
Same eng. with "0" deck = 9.37 to 1
Same eng. with .025 deck and 64cc heads = 10.07
Same eng. with "0" deck and 64cc heads = 10.70 to 1
Auggie
Old May 27, 2002 | 10:59 PM
89WS-6's Avatar
thanks auggie, you did the math for me. i appreciate that. That really helped out my decision. thanks,
Old May 27, 2002 | 11:09 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Smaller chamber without a piston dome is more effecient and bigger chamber and a large piston dome. You should always go with a smaller chamber when possible, large chambers simply suck.
Old May 27, 2002 | 11:10 PM
89WS-6's Avatar
alright. Now if I can only find out my chamber size. *hand on chin* hmmmmmmm.
Old May 28, 2002 | 04:01 AM
ede's Avatar
ede
to generalize a bit you'd be ahead to go with small chambers and dished pistons as long as you can get the compression ratio you desire
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
