Which Engine
Old May 30, 2002 | 04:12 PM
Trent257's Avatar
Which Engine
i have a 350TPI GM Goodwrench Crate Engine, whcih is about 4-5 years old. i would like to know the specs on it, how many hp it has stock. are there any pages which display all the gm goodwrench engines? i thought it was a direct l98, but the valve covers arnt centerbolt. please help
Old May 30, 2002 | 06:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll have to get the #s off the side of the block.
Old May 31, 2002 | 09:30 AM
Beefy89's Avatar
www.sdpc2000.com
Old May 31, 2002 | 12:48 PM
Vader's Avatar
As long as this is a 2/3 Cheeser forum (now 3/4), I'll add in. The casting numbers you need should be on the rear ledge of the case:
You might also be able to get some data from the right front cylinder deck pad:
Most of the Goodwrench engines are the "Hecho en Mejico" variety, and there is some contention over what heads and cams were used with what cases. If you have perimeter bolt rocker covers (pre-'87 style) you MAY also have a flat tappet cam, and possibly a two-piece rear main oil seal.
If you have the GM part number from the replacement engine, that would be a good start.
Oh, yeah. One more thing:
Old May 31, 2002 | 01:58 PM
Beefy89's Avatar
[/B][/QUOTE]
NOOOOOOO!!!!!!!!
Say it isn't so....I moved here from Auruora Il,and will NEVER I mean NEVER become a Packer fan......You can call me a Cheesehead but don't call me a Packer fan..........LOL
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
