I think I have spun a bearing because
Old May 30, 2002 | 06:45 PM
gmanuel's Avatar
My oil pressure is real low. I replaced the sending unit but no change. I think I have spun a bearing because. I notice the low pressure after a hard accelleration. Or is it the oil pump? Before I pull the engine is there a way to determine which is the problem? The engine has about 10k on it.
Thanks Gary
Old May 30, 2002 | 07:02 PM
91TA's Avatar
If you have a spun bearing then you will hear a knocking that will get louder when you give it gas.
Old May 30, 2002 | 07:31 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
What is the oil psi at idle and when its rapping? From what you say is that it decreases after hard accelleration ??? I have seen oil pump pickups (screens) come off and cause similar problems.
Old May 30, 2002 | 07:37 PM
ede's Avatar
ede
first thing i'd do is put a mechanical gauge in the block and get a truer reading than the factory gauge. spun bearings aren't that common, i suspect something else, after i did the new gauge.
Old May 30, 2002 | 08:00 PM
ronterry's Avatar
Car: '94 Corvette
If it's not diddie diddie knock knock knock diddie knock knock, then you didn't spin a bearing.
Man the last time I spun one the engine died, and we added like 3 quarts on top of an already full crank case. Then we needed a diesel truck to turn it over. Turned the idle up real high, and made it home.
Good oh rod bearing #6...
Ron
Old May 30, 2002 | 08:16 PM
gmanuel's Avatar
There is no banging or clanking. The engine is just as quiet as before. The oil pressure is in the red zone. As I rev the engine there is a slight increase in pressure. The water temperture has remained the same level.
Old May 30, 2002 | 11:13 PM
ronterry's Avatar
Car: '94 Corvette
Do what 'Ede' said... You can buy a cheap one for around 10 bucks...
Connect it on the side of the block above the oil filter. That's usualy the easiest place to get to.
Ron
Old May 31, 2002 | 08:35 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I spun the #5 rod bearing on my motor last summer,believe me ,you'd know if thats what you had.It was hardly there at idle,but when you up the revs,it gets the knock-knock sound everyone is talking about.It sounds like a gauge or oilpump problem.Do you have slightly more pressure when the car is started in the morning?If not,i would suspect the gauge too.I've read the senders can go bad on those electric gauges.
Old May 31, 2002 | 10:55 AM
gmanuel's Avatar
Thanks for the replys. I got a mechincal guage installed and everything is fine. The problem was with the guage. There is a resistor across two connections on the guage. It had opened. I had an instrument cluster from an 82 z and used the resistor from it.
mrbird
Oct 20, 2015 03:43 AM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
