smog pump for A.I.R system
Old Jun 2, 2002 | 01:18 PM
hawaiianguy's Avatar
If I dis-connect the smog pump for my A.I.R. system and pull the hoses out and plug the hose ends and tubes in the exhaust manifolds, do I need to get a shorter serpentine belt, or is there a vendor who sells an idler pulley to take the place of the smog pump pulley? Also can I expect the ecm to give me a trouble code as well as a "SERVICE ENGINE SOON" warning indicator? Will removal of the smog pump and A.I.R. system have any detrimental effects on driveability as well as engine performance?
I figured while I was working on my idle problem, I might as well do away with all the above at the same time. Having to pass emissions in Hawaii is just about non-existent.
Thanks for your ideas ahead of time guys and gals.
Old Jun 2, 2002 | 02:44 PM
wataru's Avatar
#1 Yes you will need to get a new belt
#2 No, GM no longer sells the smog pump delete pulley
#3 The ecm wont even miss it! and
#4 Its not gonna make the car run any worse if thats what your worried about.
Later Barrett
Old Jun 2, 2002 | 03:25 PM
Patrick007's Avatar
BTW... with the new way of routing the belt you'll actually need a longer belt.. just so ya know... 965K6 I beleive.. but check the tech article
Old Jun 2, 2002 | 07:51 PM
Dex's Avatar
Dex
If you want to get exact on the belt it 96.5" my stock belt is 98" routed the same way it is in the tech article from the factory so to remove the air pump it needs to be 1.5" shorter on my application it should will work on yours too:lala:
Old Jun 2, 2002 | 10:19 PM
johndo1707's Avatar
#3 The ecm wont even miss it! .....
the ecm missed mine!
9192camaro
16
Feb 3, 2019 12:21 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
beachrodder
Aug 25, 2015 08:05 AM
mustangman65_79
Aug 7, 2015 09:55 PM
