running funny
Old Jun 3, 2002 | 10:46 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
running funny
I have a 91 firebird 305 tbi it has a edelbrock cam and intake combo on it from summitt i have pacesetter headers on it also with a perf chip by hypertech just recently if i unhook my battery and hook it back up my car will not start i have to unhook the tbi injectors then start it and then run back to hook them up before it dies sometimes takes a couple of tries also when i drive my car and it gets hot if i try to start it it lopes badly and jumps up and down on tach if i rev it up it slowly smooths out please give help nick
Old Jun 5, 2002 | 10:55 AM
Vader's Avatar
91,
If you have to disconnect the injector connections to start the engine, you're flooding. The only ways this can happen on an EFI engine are due to leaking injectors or a shorted (grounded) wiring harness to the injectors. I'd suggest starting with a fuel pressure test with the engine both running and off to monitor leakage.
Old Jun 7, 2002 | 12:51 AM
Engine: 383
Transmission: th350
thanks for the info sir
if there leaking injectors does that mean i have to get new ones and if i do what can i do to get better flowing ones like 350 tbi injectors thanx again
nick
eightsixseven
Dec 16, 2024 01:50 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
