compression ratios
Old Jun 23, 2002 | 08:22 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
compression ratios
I have a new set of tfs 23 degree aluminum heads with 64cc chambers. I was wondering if anyone knew how much to mill these to get 58cc chambers? I have a internally stock 90 model l98 and would like to get 10 ,10.5 compression from it.
thanks in advance for your help.
Old Jun 24, 2002 | 02:41 AM
rezinn's Avatar
Probably a couple hundred bucks. $250 maybe.
Old Jun 24, 2002 | 10:55 AM
HatchetJack's Avatar
If your machinist can't give you the amount for this change off the top of his head---GET A NEW MACHINIST---
Actually this is something auto machinists deal with kinda frequently and they have the numbers--or if it is some weird never before seen head they can C.C. it--but usually small block heads are a standard daily procedure.
Old Jun 24, 2002 | 01:24 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's about .006" per cc.
Be sure you can get the required octane gas nessessary to
run 10.5:1 cr before ya do this.
10.5:1 cr on 92 octane is pushing it.
The way I figure it you could bolt on those heads at 64 cc
on your stock motor with a factory style .015" shim gasket
and get 10.28:1
Bore 4.00, stroke 3.48, deck clearance .025", flat top piston valve relief vol 5cc, .015" gasket vol 3.5cc head cc 64cc
If this turns out to be too much compression,
a .028" gasket will be 9.97:1
Old Jun 24, 2002 | 03:06 PM
slayer2000's Avatar
Car: 1990 GTA
thanks for the replys. I didn't know there was a steel shim gasket on the L98 but I've used them before so thats okay. I thought with aluminum heads you wanted to run about 10.0-1 because of the heat lost compared to cast iron? If I can get 10 to 1 without milling my heads then thats great.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
